Any info on weather eibach has a kit out??
I spoke to Eibach last week and they said a newer kit that's better suited to the HHR is due out in early Feb. Also a sway bar kit about the same time.
At the rate GM is delivering the HHRs the timing should be good! ;-(
There is already two out. They have both pro and sport setups.
When I did my mustang I went with the Mach 1 setup because it only dropped me like a 1/2 an inch to a inch. I never actualy took mesurements but you could tell the difference sitting next to the stock suspension.
Wise choice there. I would hate to spend a ton for rims and then find out that there are clearance issues later.
Some 10" - 12" wide rims in back would sure look nice.
Too bad the HHR isn't RWD.
