Any sway bar bushings better than others?
2009 LS. 58k on car. New struts at 40k, new Moog sway bar link ends at about 50k Moog LCA bushings this summer. Still have a clunk, seems more noticeable first thing in morning. Also seems if I turn wheel back and forth like I'm auto crossing I can make it do it. Didn't replace bushings because car is clean and they appear to be tight. At this point I figure I'll do it just because. Noise does seem to be from down where the sway bar is. What bushings are you guys using?
Thanks. |
It seems the OEM are best for that, I've tested different ones and , well I'm going back to OEM
Here the link to that https://www.chevyhhr.net/forums/how-...ushings-59204/ |
At least look at the LCA rear bushing.
don, I have replaced everything but the sway bar bushings..
