Anyone have experience with the electronic steering?
My car, pretty abruptly, began to steer rough at low speeds. Having done a little research, I found that it's likely the motor or an electrical issue. Anyone gotten that far into the rack?
I'd like to know if there's anything else that would cause the motor not to turn on.
In most cases it's the motor that fails but I have read that there are a few that the problem was the rack it's self.
Here some reading that may help. Also the search box will pull up many more threads about power steering.
https://www.chevyhhr.net/forums/how-...-w-pics-31289/
Like said above the motor is usually the culprit.
If you do find that the motor is the problem then take it to the dealer to be replaced as they are covering the motors under an extended warranty setup right now. A search on here will bring up a thread about that coverage.
Hi gamma-wes,
I’m sorry to hear of the difficulties that you have been experiencing with your HHR. I cannot guarantee anything, but I will be glad to contact your dealership on your behalf in order to further discuss your concern. Feel free to send us a private message with your full contact information, VIN, current mileage, and dealership name if any extra help is needed. I look forward to hearing from you soon!
Kristen A.
Chevrolet Customer Care
Kristen A.
I did some reading on diagnostics and the only thing that makes sense with all of the symptoms is the motor. I'll get on that next weekend or so. I can keep the car parked that long.
Hi gamma-wes,
Kristen A.
Kristen A.
