Best Coil-overs for the buck and handling?
What are the best coil-overs for the buck? I want something that I can instal with having to take it to a shop for an alignment. But something that is adjustable and will make a huge difference in cornering/ handling. Thanks again. Links to a site would help too.
I probably won't be read to buy a set till Jan time frame to be honest, if I'm spending that much. Any other suggestions? Also, can I order a INJEN intake tube only? No filter....
Keep in mind you pay for what you get in coil overs. If you just want low, dont care about handling, then you can get cheap china made ones. Really only true non-china made ones are Pedders and KW.
Wow...KW....
That is the Rolls Royce of aftermarket suspensions, as far as I'm concerned. They are really built to take punishment too. But be prepared to pay really big bucks. Probably 2-3 times what Pedders charge.
Actually, they are cheaper: http://www.autoanything.com/suspensi...15A2827A1.aspx
but do they require adjustment?
It depends on which ones. I think there are about 8-10 different groups of suspensions. I suggest you go to the KW suspension website and look for what is in your realm. You can search for price later, at other websites.
I had kw Varient 2 on my ford racing ford focus loved them! also my eclipse but that was sponsored saved me alot of money$$ had to run their stickers all over the car though.
Loved how quick at shows it took to drop the eclipse to the ground.
jeff
jeff
