Brembo Upgrade Questions
Old Jun 21, 2019 | 10:09 PM
  #41
I recommend melatonin to get to sleep while worrying things to death.
Old Jun 22, 2019 | 05:25 PM
  #42
Assume the MC delivers fluid at a pressure of 2 PSI to a cylinder with 2 square inches; then deliver the same 2 PSI to a cylinder with 4 square inches. Do they both have the same output?
If you have to worry about changing it, why change it?
Old Jun 22, 2019 | 06:36 PM
  #43
How bout this Don. Jack up your car with a floor jack and note how much handle pressure it takes to lift the car.
Now, with the same jack, do it again but this time with a board (twice as big as the jack pad) between the jack and the car. Bet it takes the same amount of pressure
Yes we can talk this one to death. Or maybe we have................
Old Jun 22, 2019 | 06:38 PM
  #44
The Brembo pad surface is much larger then the stock GM pads.
The presure will be the same as before the swap , the car will stop better then before , the ABS will still function.
Old Jun 23, 2019 | 10:17 AM
  #45
But, disconnect one of the plungers on that jack and you can't lift the car. My jack has 2 pumps, one of them regularly sticks.
Old Jun 23, 2019 | 11:18 AM
  #46
gio89kid's Avatar
I was wrong about the calculations:
There is a big difference between floating calipers and fixed calipers.
The piston area of a floating caliper must be multiplied by 2. This is because the caliper area is between itself and a wall. Where as a fixed caliper like the brembo has the piston area pressing against other pistons. Equal forces cancel.
So that makes sense now that the piston area of the non brembo SS caliper was half of the area of the brembo. Because they are floating you multiply that by 2 and you get the exact same caliper area, but with bigger pads and rotors it’s still an upgrade, still assuming equal pressure from not changing the booster or MC to match the SS Brembo version.
Brake caliper:
SS non brembo uses a single piston that creates .56sq.in. of piston area x2 for floating caliper = 1.12sq.in.
LS/LT uses a single piston that creates .7sq.in. of piston area x2 for floating caliper = 1.4sq.in.
SS Brembo uses 4 pistons that create 1.12sq.in. of piston area.
If you add in the fact that it is a bigger rotor with bigger pads, the less area from the Brembo vs the LS/LT should be made up for.
This would also mean ABS is definitely not affected by piston area.
Old Jun 23, 2019 | 03:17 PM
  #47
Blue_SS's Avatar
You are going to need more than Melatonin...
Old Jun 23, 2019 | 09:43 PM
  #48
Old Jun 24, 2019 | 01:33 AM
  #49
Our fish was found dead in the tank - so that is proof that fish can drown.
Old Jun 24, 2019 | 09:08 AM
  #50
Hard to prove, they always have water in their gills. Possibly lack of oxygen in the water.
