Ceramic brake pad vs Standard rotor
Old May 14, 2012 | 12:15 AM
geg's Avatar
geg
Doubts strangle me.
I have a ceramic brake pads, it is peacefully lying in my closet for 2 years. Yesterday I installed it on my car.
Experienced people say to me: "Cerámica - this is good, but remember - this is good only for " perforated " rotor. Ceramic brake pads will eat standard rotor in a short time. In addition, poor braking. And if the standard rotor overheat - total failure of brakes. "
Yesterday I drove through the city - I do not feel discomfort.
Guys, what do you think about this?
Old May 14, 2012 | 09:28 AM
Blue_SS's Avatar
I think you will be fine. I used higher-friction performance pads with plain rotors on my last car in autocross events, and had no issues. I believe that drilled and slotted rotors are only for appearance in most modern applications. If you are going onto a track and braking heavily, the answer is different. On the street, you won't get enough heat in them to notice any difference.
Old May 14, 2012 | 10:17 AM
SpaceCowboy's Avatar
drilled/slotted are for extreme high performance situations such as full on braking back to back...you will be fine unless you are doing a lemans race in your HHR
Old May 14, 2012 | 01:46 PM
1970judge's Avatar
Drilled/Slotted rotors are for looks in most (almost all cases). I can show you C6R rotors/Lamborghini RSv rotors, neither are slotted. Drilled and slotted rotors are an old school technique that followed through to today, unfortunately.
Old May 14, 2012 | 03:25 PM
the Lamborghini Aventador has drilled rotors
Old May 14, 2012 | 03:58 PM
Doc brown's Avatar
Ceramic pads are OEM on most cars today. You should not have any issues with them.
Old May 14, 2012 | 08:38 PM
geg's Avatar
geg
Thank you, guys. You reassured me.
gypsycookie
14
Oct 2, 2013 04:17 PM
rainmanva
Maintenance and Upkeep
Aug 13, 2013 07:39 AM
nbasso85
Aug 16, 2012 10:56 AM
wagoneer
Jul 31, 2009 04:23 PM
