Cobalt rear brakes on HHR
Old Apr 13, 2009 | 11:34 AM
gimpy's Avatar
Has anyone explored fitting the Cobalt rear discs to the HHR to give it discs on all 4 corners.
Maybe it's athought for vendors!
Gimpy
Old Apr 13, 2009 | 11:50 AM
09 Panel's Avatar
Do a search, it's been done by someone here.
Old Apr 13, 2009 | 01:13 PM
masterchief1112's Avatar
Search function is your friend. here ya go disc brakes. if you could find a wrecked cobalt ss you could essentially pull the entire rear end off of that and transplant that onto the HHR.
Old Apr 13, 2009 | 01:20 PM
hvrod's Avatar
Talking
Basically everthing bolts/fits up..
I did braided brake lines, so I had to clamp, use supportive brake fittings
to mate with existing line on car...
You will also need the emergency brake cables from the SS..
Old Apr 13, 2009 | 03:31 PM
garagebuilt's Avatar
do you just pull the bolts on the back side and take the whole drum assy. off?
Old Apr 13, 2009 | 03:42 PM
hvrod's Avatar
You need to purchase the rear axle SS unit too..
It has the welded plates/brackets that has the mountings for the
rear disc brake calipers...
Old Apr 16, 2009 | 10:02 AM
gimpy's Avatar
Cobalt rear brakes
Thanks for the replys. I don't have an HHR yet & wanted to find out so I could convert after I get mine. After yrs of 4 wheel discs (mustangs,Porsche, SHO, etc) I'm spoiled!
be back after I'm offically an owner.
Gimpy
Chillydip
14
May 8, 2015 07:23 PM
mrarff
0
Jan 7, 2011 08:15 AM
Hiperguy
Nov 22, 2010 09:28 PM
c2vette
Sep 4, 2009 07:58 AM
camaro98z28
Oct 1, 2008 07:45 AM
