My rear control arm bolt, which is also the subframe bolt, would unscrew but not come out because it was seized in the steel bushing that goes through the rubber. Instead of coming out it was pushing that corner of the subframe down.
I didn't realize the exact situation until I read this thread.
I wanted to try to save the bolt because I can't find a replacement until Monday and I have to drive to work. Everywhere is 20 miles from home.
I whittled most of the rubber out with a hot kitchen knife then sliced the aluminum control arm around where the rubber was with a torch. At this point it was easy to pry the cut wide open while it was still hot.
Now all that was left was the bare steel bushing and the bolt seized within. I was able to apply heat to the bushing and 'pop' the subframe sprung back up when the bolt un-seized.
This seemed to work well. I took care to use scrap sheet metal to shield other parts from heat and flame. I used an oxy/acet torch and unlike steel the aluminum maintained shape until hot enough then slumped out all at once.
Well, cleaning up fasteners this morning it appears the bolt has seen better days. It's thinning around the center and should probably be replaced. Oldblue, do you know if there is a parts store replacement for this little stinker that I could get on a Sunday?
Thanks, those chassis bolt pictures look similar but on mine the threads extend half the length of the bolt. It could be that it doesn't matter or the pic is of a different but similar part.
A couple desperate times this weekend...
1. I used a thread file to clean up that raunchy chassis bolt and re-used it for now (with antiseize). I think it would actually be fine but I'll be happier when I get a new one.
2. I 'renewed' the 30 degree taper (60 degree in lug nut speak) on 5 buggered lug nuts. I think I'm going to buy new ones soon though. Probably a set like this for my winter steel wheels and a set of acorn style for my aluminum wheels.
