Eibach or Goldline?
Old Nov 5, 2007 | 03:32 PM
A couple here a running sportlines; they haven't mentioned any issues that I know of.
Someone posted some specs about the Progress Tech's springs that were pretty close to the 1st gen GL drop.
Old Nov 5, 2007 | 03:44 PM
betterof2evils4's Avatar
Progress Tech... The same company that makes the sway bar?
Old Nov 5, 2007 | 03:49 PM
chingchonger's Avatar
Running Eibach Sportline made for the Cobalt. No issues and looks good. I have them on my panel. Probably no issue because I don't have seats/passengers in the back. I do wish that the rear spring rates were a little higher.
If anyone is experiencing a harsh ride, did you remember to trim the bump stops?
Old Nov 5, 2007 | 05:37 PM
1Panel2NV's Avatar
3rd gen Goldlines here. I think they ride good. A little stiffer than stock, but not harsh by any means. I wish I could get a set of 1st gens though. I'd like to be about an inch lower.
Old Nov 5, 2007 | 07:44 PM
Don Juan's Avatar
What are the lowering specs differences on goldline through the generations?
Old Nov 5, 2007 | 08:04 PM
TurboTechRacing's Avatar
Former Sponsor
Correct they are using sportlines by Eibach, however we wanted to post what Eibach stated about the Sportlines when we talked to our rep, they just stated "The Pro kit has been tested and acceptable, the Sportlines do not offer enough spring rate in the rear for the HHR"
Customers can choose the sportlines still, as it is their choice :)
Old Nov 5, 2007 | 08:05 PM
1Panel2NV's Avatar
I remember seeing a comparison around here somewhere...
You probably won't be able to get a hold of anything besides 3rd gens, unless you know somebody that wants to get rid of them.
If anyone has a set of 1st gens they want to get rid of I would probably take them off your hands.
Old Nov 5, 2007 | 08:50 PM
Don Juan's Avatar
On truck shop its has some gold lines that have 1.75 inches in the front, and 2.125 in the rear. what generation is this. it does not say on there.
Old Nov 5, 2007 | 08:59 PM
Don Juan's Avatar
i also just found some goldlines that have the same up front but only a 2inch in back. what generation are these. they are at this website.
http://www.automotiveconcepts.net/st...uspension.html
Old Nov 5, 2007 | 09:17 PM
1Panel2NV's Avatar
I assume the part number for the 1st gens is 1260, 2nd is 1261, and 3rd is 1262. I'm only sure about the 3rd gens though, since that's what my box had on it.
