Finished Eibach Sportline Springs they fit.
Old Jan 19, 2008 | 06:32 PM
chingchonger's Avatar
Originally Posted by KNEZRYD
I don't want to hurt anyone's feelings, but I had the pro kit on my HHR for about a year and a half, maybe two, and I swaped the rears out for stock this week because it bottoms out. I think that because they were desingned around the cobalt, the extra weight of the HHR in the rear is to much for that little spring. All you have to do is look at them side by side and you will see it. If you have them already I hope it works out. If you haven't decided and your looking into the eibachs I would do my home work first
I have the sportline on my panel. I wouldn't recommend it for a standard HHR for the same reason mentioned above. Also, if you have a lowered car, you NEED to drive slow over speed bumps and dips, regardless of the brand of springs. If you can't do that, then a lowered car is not the best thing for you.
Old Jan 19, 2008 | 06:38 PM
Z-Man's Avatar
Next Week, Come on Man
Pics Pics Pics
Old Jan 19, 2008 | 06:52 PM
Pics Pics Pics
If you want pics, go here:
https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/hhr-panel-eibach-sportline-9330/
and here:
https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/new-20-wheels-10706/
Old Jan 19, 2008 | 08:55 PM
Hotrodbob's Avatar
I put these springs on my panel and it does bottom out. By bottoming out I mean it hits the bump stops.
The ride is ok. The rear springs suck. The top coils are colapsed. That hurts the ride. They should have done a progressive spring. If there is a lowered rear spring that is not colaped like this, I'd like to know.
Old Jan 21, 2008 | 01:22 AM
NORCAL SS's Avatar
didnt see it posted my bad.
Old Jan 29, 2008 | 10:43 PM
  #26
Did you remember to cut your bump stops 3/4" before reassembly? If not, there lies your problem.
Old Jan 29, 2008 | 11:01 PM
  #27
KNEZRYD's Avatar
That is true unless you have a wider tire such as my 225's, where it bottoms out on my tire.
Old Jan 30, 2008 | 05:06 AM
  #28
rob-cyn's Avatar
Does anyone make a drop kit with less drop, like 1"-1 1/2" ?
Old Jan 30, 2008 | 04:51 PM
  #29
fontana motorsports's Avatar
im running the sportlines, not a terrible ride at all,i do think they should raise the rate of the rears though.. im putting a set of air shocks in the rear to compensate with a load in it..the shocks arent "bolt in" but are the same length,and travel, only the bushing sleeves are different... but i love the look with the sportlines..
Old Jan 30, 2008 | 04:52 PM
  #30
yes the eibach pro kit is closer to that.
