Front Control Arms
Old Aug 23, 2018 | 06:08 AM
OldSwede's Avatar
Yes, sir. Thank you - and the other "veterans" - for your help to this newbie.
Old Aug 23, 2018 | 02:24 PM
Cat Man HHR's Avatar
Originally Posted by Oldblue
Make sure he doesn’t just rattle those bolts with an impact wrench, they are to be properly torqued!
we have the procedure in our how to section
Don't know about that. I just replaced my front struts and all I used was an impact gun. Been doing automotive work for many years and at times you just tighten bolts and not follow a manual. If you know how tight is tight, you'll be OK. Yeah, here comes the flack now.
Edit: Case in point. You have a flat on the side of the road. Put the spare on and it's raining! Do you have your torque wrench out to properly tighten the lug nuts ?
Old Aug 23, 2018 | 05:51 PM
Well yes, I do carry a torque wrench for just such an emergency!
as for proper torque specs on especially suspension parts should be followed, however, it’s your decision, if you think tight is tight, well then alright!
Old Aug 23, 2018 | 07:31 PM
When the spec is 89 lb.ft. then 180 degrees I don't trust the impact wrench. wouldn't know what is tight when it comes to holding the entire car off of the ground under lots of other forces. In most instances I use the "redneck torque wrench". I never trust an impact wrench for final tightness, how could a normal person ever find out how tight it was.
Old Aug 23, 2018 | 11:46 PM
"Do you have your torque wrench out to properly tighten the lug nuts ?" nope, but I'll throw a torque wrench on it at home asap.
A few of us, maybe most of us, after wrenching for a few years, can get pretty close to the torque specs without a torque wrench.
But hey if one has invested in a T. wrench we just gotta use it to keep the lil lady from complaining about all the tools we never use.
Old Aug 24, 2018 | 07:05 AM
  #26
HHRerrr's Avatar
89 pounds then another 180 degrees? Is that really the 'spec'? Kind of odd isn't it? I'll assume a 'red neck' torque wrench is a breaker bar. I don't get out much anymore.
Old Aug 24, 2018 | 07:48 AM
  #27
180 degrees is the easier one. Some specs have an additional 30,45, 60 degrees etc. on top of the basic "snug down".
Wanna have fun, read through this link: https://www.chevyhhr.net/forums/how-...e-items-54648/
P.S. AND, make sure you get the in. pound and ft. pound values correct.
(I'm done. Gave myself another headache.)
Old Aug 24, 2018 | 08:09 AM
  #28
Red neck torque wrench is based on which wrench you use (1/4,3/8,1/2,24 inch,32inch),which hand is holding the beer,how many huffs and puffs etc.
For instance; 200 lb.ft. is the 32 inch breaker bar, beer in left hand no huffs. 220 lb.ft. is 32 inch,beer on bench,
79 lb.ft. is 3/8 drive beer in right hand snug; 89 lb.ft. beer in left hand snug.
Old Aug 24, 2018 | 08:48 AM
  #29
HHRerrr's Avatar
That sounds like valuable info, and I should probably make note of it. Now, if I could only find my pencil!
Old Aug 24, 2018 | 01:24 PM
  #30
1/4" torque is your fingers, 3/8" is your wrist, 1/2" is your shoulder, 3/4" is your leg.
