front end noise
Old Jul 28, 2009 | 12:09 PM
DreamHHR's Avatar
Originally Posted by Ted123
I don't think moog makes them yet.
12 mm course thread, poly lock nut and lock washer. The nut is 19mm and you will need a 17mm flat wrench for the other side
What length is the bolt?
Moog #: K750012 for the HHR
Yves
Old Jul 28, 2009 | 12:15 PM
Ted123's Avatar
To determine if it is the same problem, turn the wheel full right to check the left wheel. Rock the car by the door frame and see if the upper link moves. When the locknut strips it will elogate the mounting on the strut, thus the clunking noise. Although mine was elogated, by using the poly lock nut and "proper" lock washer, there is no movement or noise. Either that or replace the strut and link again with new grade 8 hardware, which G.M. should have used in the first place. It probably saved them $ 5.00 per car.
Ted
Old Jul 28, 2009 | 12:18 PM
Ted123's Avatar
What, the bolt on the link pin, long enough. the problem isn't the link pins, its the cheap hardware they use.
Ted
Old Jul 28, 2009 | 12:49 PM
DreamHHR's Avatar
Ha, I get it; of course you only replaced the nut, because the bolt is part of the link itself.
I'm only thinking about Moog link replacement for when the lower link joint goes bad next time. That's always been the problem with mine, except that now I can hear clunking and it's not the lower joint; that's why I think that it may be the top bolt moving.
I'm at 63000 km, and I already went through 3 end links, 2 struts, one set of bushings and one wheel bearing; and so far most GM replacement parts fail faster than the previous ones.
I mean, I don't expect these things to last forever, but they did on my last 3 previous cars....for well over 200000 Km.
Yves
Old Jul 28, 2009 | 01:17 PM
Ted123's Avatar
I'am at 196,000 km. My wife's Venture Van has over 200,000 km and nothing has been replaced.
Ted
Old Jul 28, 2009 | 05:09 PM
  #26
R CA HHR's Avatar
anybody take any photos of where this is happening, or a video?
Old Jul 28, 2009 | 05:20 PM
  #27
Ted123's Avatar
No photo's. If you look just inside at the top of the tire you will see where the link connects to the strut. This is where the lock nut has been failing.
Ted
Old Aug 1, 2009 | 01:51 PM
  #28
Gadson03's Avatar
Unhappy
I am also hearing a noise from my 06'. My husband thinks it may be the CV joints because you only hear/feel it if you are turning to the right? I only have about 45,000 on her, is this normal?
Old Aug 1, 2009 | 11:03 PM
  #29
Ted123's Avatar
I have almost 198,000 km on mine, the only problem i have had is front end noise while going over bumps and ruts in the road. I have not heard of anyone having cv problems. It is possible though.
Ted
Old Dec 14, 2009 | 01:42 PM
  #30
mikiec's Avatar
Has anybody tried to lube the intermediate shaft? I found this while doing more research into this problem:
http://www.gmtruckclub.com/forum/showthread.php?t=18106
Mike
