Fuel Filler tank hose, or?
I'm suspecting a slight leak from the fuel filler neck hose. Is this or a nearby part a common issue? When the air is still, I smell a very slight fume coming around that area and near the right tail light. It isn't inside the cabin at all, and nothing from the front or left rear. I've replaced the OEM Gas Cap with a Stant. It's definitely helped, but still present. Very localized. I will be taking it in tomorrow to get the 3 recalls fixed, so tomorrow's my chance to ask them as well. I just don't want the dealer trying to sell me a $2000 repair for something I could replace. I've had dealings with my GM dealer, who always tries... lol
Last edited by planetrj; Feb 2, 2020 at 06:50 PM. Reason: added - I've replaced the gas cap
Thanks for all the help... Seems like all of these quirks are just the things that are standard for them, and nothing out of the ordinary, or not experienced on here.
Do they salt roads in Hawaii ?
Unless this car was shipped used from the mainland. Then it's a possibility.
I'm not breaking your shoes, would like to know the OP answer to this.
If there are no codes, that's a big clue. It's not in the evap system. It's filler pipe, tank, or lines. The evap system is designed to contain fuel vapors. Leaks there cause codes.
I still need to check the lines but I just ordered a Chilton manual on Monday so I can see the diagram and know exactly what I’m looking at. It’s crazy how much the fuel line structure can vary between GM makes/models. The book should arrive on the weekend or so, so I’m planning to tackle that this coming week. I want to be safe rather than sorry, since it’s dealing with gas.
