have rotors turned or go with new rotors?
I've got an '07 HHR LS with 60,500 miles that I just got less than 2 weeks ago. I am running into noticeable pulsing, although nothing bad enough to shake the wheel. Having done my homework, I pulled out the dial indicator and micrometer. I checked the bearings front and back and none of them have any excess play. I could hardly get them to move .001" for that matter.
The front left rotor has a runout of about .004", while the thickness taken at 3 different points is .997" consistently. This leads me to believe that this rotor is warped slightly for some reason. I realize that some threads I have read here claim this is impossible, but my micrometer says otherwise. I don't see any thickness differences in the rotor. The front right rotor has a runout of only .001", and the thickness is at 1.004" taken again at 3 points. Now my question is whether I should have the left rotor only turned, both rotors turned, or just replace both rotors outright. From what I see comparing what the NAPA website says to the service manual, assuming this car uses the JL9 rotor, the min allowable thickness after turning is .906". Given all of this detailed info, which way would be better? A local Oreilly Auto Parts store only charges like $10 per rotor to turn them off of the car (if my memory serves me right). I would go ahead and put new pads on either way I go as they are over 1/2 worn. So should I just turn one or both, or cough up the $60ea for new rotors? |
Whatever ya do, do both... Never just one.. Just my .02
Originally Posted by sleeper
(Post 491373)
Using your numbers, as long as they don't take more than 0.098 away you are still within tolerance. After that, how long will it take for you to get below tolerance with normal driving? If you are doing the work, it's your time you are working with.
Most shops that turn them will check specs themselves as well. If they are borderline they'll tell you.
Try the local parts store over the "big box" stores. |
Monday I'm going to check with the local Oreilly's as I know I've asked before and they turn rotors fairly cheap. If they want anywhere near $20 ea, then I'll probably just buy new ones. Makes sense that it is probably better to turn both sides so that the brakes don't pull to one side.
Originally Posted by voigtsga
(Post 491602)
Your end-play on all wheels sounds almost like-new... That's a Big plus that you checked them.. The run-out on the rotors will clean up if that's the way you go.. If you replace everything, I hear nothing but good about Napa rotors & pads. (& I don't work there).. |
(Post 491621)
Absolutely, & you said you're adding fresh pads.. So really gotta "turn" 'em both, or replace 'em both. To do it proper.
Your end-play on all wheels sounds almost like-new... That's a Big plus that you checked them.. The run-out on the rotors will clean up if that's the way you go.. If you replace everything, I hear nothing but good about Napa rotors & pads. (& I don't work there).. I too hear nothing but good things about the NAPA Ultra Premium rotors. I like the fact that they are made in the USA, and not China as most of them are. Its also hard to beat a lifetime warranty. I think a number of the rotors that I see with the cross-drilled and slotted stuff are really overpriced. |
2 Attachment(s)
voigtsga-
I think that's the best thing any of us can do, is do the research on any un-knowns...And know just what to watch for.. Agreed checking end-play & run-out is easy, but seems often overlooked by many... I can see how easy a stealership could BS someone that has no clue.. Best to try & be as informed as possible...:twothumbs: |
I just replaced both rotors and pads on my '07. Cost me about 100 bucks and an hour of my time. My rotors had been turned once while still under warranty. The dealership wanted $120 (which I thought was a bit excessive) to just turn the rotors last time I had it in the shop.
