HHR SS Front Rotors warped. Need Help!
I have a 2009 HHR SS and my front rotors are warped. Big surprise there, huh?
I need to replace them. Mine is a non-Brembo and I am thinking about EBC reds Stage 4, but that is not set in stone. I wanting a brake kit for oem calipers with better rotors and pads. I keep finding multiple kits and not sure which one to get. Where can I get the best price on a kit with the rotors and pads too? Recommendations and part numbers as well as the best site to get them from would be wonderful! Thanks. |
1 Attachment(s)
Are you sure it's the rotors and not the LCA rear bushings or maybe ball joints or tie rod ends? I just fixed my brake judder, with new LCA bushings, I have the non Brembo SS rotors on my LS.
Originally Posted by Oldblue
(Post 785071)
But I will check that out. What do I need to do see if that is the problem? |
Could be the rotors, mine was a shake issue after a drive in the Smokey's along thru to Gatlinberg and Pigeon Forge, I upgraded to the SS nonBrembos, still had the shake, so next was the LCA bushings problem solved, that was 4 years ago, the last 2 months the shake started up again, Monday I changed out the bushings to the Moog problem solvers, no more shake!
Found the bushings. I am going to check them too. They seem to be about $15 so that will be a cheap fix if I need them.
Now I just need to find a part number and best price for the rotors and pad kit. In other words, what is the front brake size so I can find the right kit? This is what I am thinking of getting if they are the right ones that I need. http://www.summitracing.com/parts/eb...olet/model/hhr |
Don't waste your time or money on $15.00 bushings go with Moog K200792 check out moogproblemsolvers.com
