hose for brake booster
Old Aug 25, 2025 | 11:48 PM
kmdakota1's Avatar
anyone know the part number for the vacuum hose coming off the brake booster to the intake? Can't seem to find one on RA. Autozone sold me some basic vacuum hose but it's collapsing under vacuum.
Old Aug 26, 2025 | 06:54 AM
20919375 Comes up in GM parts Canada listings but there’s no fitment listed for the HHR
Old Aug 26, 2025 | 11:28 AM
I seeHome 2009 Chevrolet HHR SS 2.0L L4 - Gas Master Cylinder - Components On Dash Panel 20917172
Vacuum Hose - GM (20917172)
Doesn't appear to be anymore new left. You should try getting a used one
EDIT: nevermind, I thought you had an SS.
Old Aug 26, 2025 | 11:48 AM
If AZ sold you some “vacuum “ hose, I’ll bet it wasn’t vacuum rated. More likely some type of evap breather hose. Any size vacuum hose shouldn’t be collapsing. Unless it was the wrong type hose.
Old Aug 26, 2025 | 12:27 PM
Vacuum hose should have the specs printed on it. A real power brake vac tube will have a DOT on it.
https://mpbrakes.com/picking-the-pro...TcNSTAv4I5QrBB
Old Aug 26, 2025 | 02:32 PM
kmdakota1's Avatar
It looks like any GM parts warehouse that has it says its discontinued. There was one that came up for a 2006 they had in stock. I'm sure it's the same. They wanted $20 something for the hose then another $20 something to ship it. I said no way. Went to the junkyard and pulled one. Took it home and closed off one end and mighty vac on the other and no leaks. Works fine. Junkyards are like Harbor Freight to me!
slonny
Sep 11, 2020 11:17 PM
Maddie Leslie Stoddard
Jul 1, 2020 05:23 PM
promod62
Nov 12, 2014 05:50 AM
REDHHRSS
Jul 20, 2012 05:45 PM
Chris-HHR
2.4L Performance Tech
7
Oct 29, 2008 08:00 PM
