where can i find the manual procedure for adjust the manual brake?
Hi all, just I replace the rear shoes and cylinder in my HHR 2006 but the parking brake not work just I need to adjust the braking cable parking and I never did that before, somebody can help me? thanks
You adjust the brake shoes with the adjusters first , then adjust the parking brake cable under the console, simply pull the console cover up , then use a 10mm deep socket
If the parking brake was working OK before you did the brake shoe replacement, then you've got something installed incorrectly now.
Either your new shoes are not adjusted up enough or you don't have the hardware installed correct.
I check and everything si fine,in the video from oldblue, the guy replaced the shoes and he had the same problem, is just adjust the brake cable, because even when I apply the pedal brake is fine so the brake work fine, is just the cable, but is procedure for that in the video(oldblue ) he explain very well, thanks
You should unscrew the nut on the parking brake cable to release tension, in order to remove the cable from the brake shoe , ebrake lever, much easier then trying to pull the spring back and holding with side cutters or vise grip pliers.
parking braking cable issues left side (driver side)
Hi today I follow the recommendation and the passenger rear side is fine now, so when I applied the parking(emergency) brake working fine for the passenger side, but the driver side not work so the wheels still spreading, I review the tension inside of the car and I saw this.
I took the pictures...where you can see the driver side is not the level of the passenger side, why? I need to replace the parking cable?, both side or just the driver side?, some help please... thanks
Hi Thanks donbrew , yes I connect to the shoes perfectly in both side, because I replaced all shoes and the cylinders also in both sides, so I in that way for sure I made the connection, maybe is frozen or broken? if is frozen is possible to repair? Thanks so much
