Lowered
Originally Posted by SoCalHHR
After lowering, you should put 100-200 miles on the car to let the new springs settle - then get an alignment.
Hope it helps,
Hope it helps,
I'd love to hear others' comments on this...
Well, having been in the automotive publishing industry over 20+ years - and lowering MANY cars, I can tell you they do!
Even if the springs did not sag-in, you still need to drive the miles in case something was not "loaded" right when installed (i.e., the spring was not sitting in it's seat properly). Bottom line: for best results wait, then align.
I'm currently in the middle of a complete suspension re-do on a '95 VW Golf... Struts/shocks, springs, all polyurethane bushings (no rubber left on this one when I'm done), ball joints, and sway bars. I'll give it a few hundred miles before aligning, just to see.
I've always aligned my cars immediately after lowering. A second alignment generally is cheaper than new tires.
Originally Posted by Mark
As long as I have been driving lowered cars (10 years and many cars), I've been told by hobbyists, professionals, and manufacturers, that quality lowering springs do not settle.
BTW: In the past 5 years I've lowered between 20 - 25 cars, and I always tell those people to get their alignment done ASAP and most do it the next day (miles vary). Not one has ever had an issue with settling over time and / or miles. -Dan
Originally Posted by dan-d
Look at it this way. If springs had to settle to their ride height over time then all new cars would settle in at different ride heights (over time), but for the most part they're pretty darned close to to each other based on any given year, make, and model.
It's pretty easy to keep factory cars consistent with the higher rates.
End of flame...
The main difference is that with lowered cars the spring rates are much lower and more inconsistent than factory height springs.
End of flame...
End of flame...
So your saying that people like Progress Tech and other quality spring makers are inconsistant in their quality control?
I'm speaking from experience here too!
A lot less stringent than the OEM spring makers.
My Eibachs pro kit on my cavalier has never settled or lowed any, and they have been on my car for a couple years now. I race it weekly and no I am not nice to them. Also my brothers tein S kit has not settled at all. The only springs I have seen settle were gold lines we put on my friends neon, and a set of progressive springs put on my friends srt4. Both neons rides wonderful, but that could be from the koni struts.
