Lowering with GM parts
Old Aug 28, 2009 | 07:01 AM
  #91
Crooz's Avatar
Help
Trying to odered some SS springs front & rear. This thread gets confussing by throwing around all the different part numbers.
Is the following statement true if I wish a set of matching SS springs for my 08 LT2 Panel ? "Front spring is 21994335 rear is 10390024"
Old Aug 28, 2009 | 09:51 AM
  #92
ZTony8's Avatar
Crooz,those are the current numbers for an 05-07 Cobalt Supercharged SS.
Old Aug 28, 2009 | 05:08 PM
  #93
Crooz's Avatar
thanks... I went ahead and bought a Eiback Pro Kit.
Old Sep 6, 2009 | 08:23 AM
  #94
HHorange's Avatar
After reading all of the replies on this thread, and only wanting to lower the rear just a little, and being cheap, I have finally ordered a set of cobolt SS springs.
I'll see what happens when I install them Wednesday................
Old Sep 6, 2009 | 10:56 AM
  #95
timberwarp's Avatar
I got a full set of cobalt ss springs used and installed only the rears. The overall stance is even. I think the rear end is probably by less 1/4 inch shorter than stock fronts. Hardly noticible and the suspension is the same as my stock lt2.
Old Sep 6, 2009 | 04:18 PM
  #96
prod's Avatar
I had just the rears on for a while. It leveled the body, but I think the rear fenders are cut a little lower as the gap was smaller.
I have the fronts done now too, only lowered the front end around 1/2", but the gaps look more even now.
Old Sep 7, 2009 | 02:07 AM
  #97
Ok, good info.. I'm thinking of lowering the rear ONLY on my 08 Panel. Just leveling..
My S-10 I had slammed... I no longer desire that effect..
Old Sep 8, 2009 | 10:42 AM
  #98
Crooz's Avatar
Question Alignment ?
so I have an appointment this friday to install the new Eibachs.
QUESTION: An Alignment guys is actually doing this work. Will Eibach Pro Kit springs require additional alighment materials/bolts? (or is there enought factory adjustment to realign it)
Old Sep 9, 2009 | 06:11 PM
  #99
HHorange's Avatar
Ok came home from work today and installed the Cobalt SS springs....
From start to finish 35 minutes.
Not a big change but just enough that I like the look ride and handling don't seem to be changed very much....
All in all I'm happy
Old Sep 9, 2009 | 10:24 PM
  #100
HHorange-
Did you measure before & after ?? What do you think you dropped, an inch ??
Does yours look level now ??
