Lowering HHR...Week 1 Update
Old Mar 6, 2006 | 03:03 PM
ng8650's Avatar
Well it's been a week since I lowered my HHR and I just got back from the alignment shop this morning.
Link: https://www.chevyhhr.net/forums/how-tutorial-library-21/spring-install-dial-up-enter-your-own-risk-986/
They did not need the front camber kit or the rear shims to get the HHR in specs (Goldline springs). I believe the guy said he didn't have to touch the rear at all. The Toe was off up front and they were able to adjust it to specs.
As for the ride...I drove my HHR to work the last 5 days. Every day consisted of a total of 70 miles round trip to and from work. It's a tad bit bouncier but nothing I can't deal with. On flat roads I can't tell the difference between stock and the Goldlines. If my stock 2LT ride was a 5, I give it now a 4. Now I'll test this week with the alignment done and update this thread next Monday.
I recommend to hold off on any camber/shim kits with Goldline springs. Someone else on this board didn't need them either. The ride is fine and is a lot better than driving my 1989 lifted 4runner, which feels like your driving a brick.
Later
Ng
Old Mar 6, 2006 | 03:15 PM
Skatetheglobe's Avatar
so you had the sport suspension right?
Old Mar 6, 2006 | 03:20 PM
ng8650's Avatar
Correct.
Ng
Old Mar 6, 2006 | 04:19 PM
booksmitty's Avatar
Lowering
You did put the shims on right?
So maybe that's why they didn't need to be touched or you didn't use the kits at all?
Thanks
Craig... booksmitty
Old Mar 6, 2006 | 04:26 PM
I think I'm gonna order the goldlines tonight..
Old Mar 6, 2006 | 04:46 PM
SoCalHHR's Avatar
You will need the camber kit if you ever have to adjust the front for an alignment. The stock HHR strut bolts are splined and do not offer adjustment. I recommend putting the camber bolts in when you do the alignment, then they will be there when you do need them.
On the rears, - strange, that's the third person I've heard of who hasn't needed the shim kits in back? Whatever works.
Go for it!
Old Mar 6, 2006 | 04:59 PM
hvrod's Avatar
really none needed for the rear ??? hmmmm
I think I'll still have them installed when my rear caliper gets sent..
Old Mar 6, 2006 | 06:03 PM
ng8650's Avatar
Thanks
Craig... booksmitty
No I did not install any shims or the camber bolts during installation. I informed the alignment shop that I had these kits in case they needed them. No rear shims needed and no front camber kit needed. The alignment shop did not need either kit at all.
Ng
Old Mar 6, 2006 | 06:08 PM
SoCalHHR's Avatar
Problem: when you do need an alignment later on, you will need the camber bolts installed. They should always be installed at the time of the drop. Shims...well, take 'em or leave 'em depending on your preference.
Old Mar 6, 2006 | 06:09 PM
SoCalHHR's Avatar
Hey NG - who did your alignment here locally? Just curious.
