Lowering the rear end but not the front.
Old Feb 27, 2012 | 05:22 PM
Joshua022's Avatar
Is it possible?
I want to lower the rear maybe an inch and a half or so, so it will be level but I can't lower the front or I'll scrape my driveway.
Old Feb 27, 2012 | 05:37 PM
LawDog88's Avatar
Goldline rear leveling springs..
Click Here
Old Feb 28, 2012 | 12:08 AM
Originally Posted by Joshua022
Is it possible?
Yes, Cobalt SS/SC rear springs will lower the rear about 1-1/2"
You will need to re-adjust the headlights after springs settle in..
Old Feb 28, 2012 | 08:37 PM
Joshua022's Avatar
Seeme like the gold line springs are sold out everywhere.
Old Feb 28, 2012 | 10:26 PM
HipHotRod's Avatar
Yes but Cobalt springs are everywhereeeeeee.............I have them as well. Levels off nicely and retains the use of factory parts donchaknow. Not to mention the Cobalt springs are wound the same way as factory springs. No coils to bang together like the Goldlines. I had them and took them off several times to get the damn clang out of em. Ended up going with the Cobalts.
Old Feb 28, 2012 | 10:34 PM
X 2, that's how we roll....
Old Feb 29, 2012 | 04:38 PM
Joshua022's Avatar
Is it just the SS springs that I need or any stock cobalt rear springs?
Anyone know of a write up on if they can be out on without a spring tool?
Thanks
Old Feb 29, 2012 | 08:21 PM
HipHotRod's Avatar
Right here. Same same for the Cobalts. You'll want to use the SS springs. No spring tool needed once the shock bolts are removed, you'll see.
https://www.chevyhhr.net/forums/show...ar+coil+spring
Old Feb 29, 2012 | 08:36 PM
Joshua022's Avatar
Ok great thanks
Old Feb 29, 2012 | 11:35 PM
Thanks
That's up to you. Using SS rear springs will drop the rear approx 3/4"...
SS springs will be stiffer..
Now, Cobalt SS/SC 2005-07 rear coil springs will drop rear approx 1-1/2"
'08-09 Cobalt SS/TC rear springs drop rear approx 1-1-8"
