Part # for Energy Suspension sway bar bushings
Old Mar 6, 2011 | 11:28 PM
Rod Run's Avatar
Originally Posted by Snoopy
use a piece of string around the bar then measure it against a ruler. Simple grade school math after that....it's the pi thing.......3.14 should be close enough.
Much easier to just put an open end wrench on it
Old Mar 7, 2011 | 01:49 AM
1Panel2NV's Avatar
I don't know if this carries over to hhr's, but check out this link:
http://www.crateenginedepot.com/stor...s-W62C188.aspx
Old Mar 7, 2011 | 09:44 AM
Mrs. DLVRNIT's Avatar
or then you can check this page with two different offerings according to the specific year:
http://www.crateenginedepot.com/stor...ents-C512.aspx
better to measure just to make sure .....
Peace .....
Old Mar 7, 2011 | 09:56 AM
diskullman's Avatar
Crawl under?
It is easily seen and measured from above
Old Mar 27, 2011 | 06:32 PM
QuickRick's Avatar
Sway Bar Bushings for a 2009 2 LT are 25MM
There,
No confusion, I measured it for real with a caliper then tried a 24MM open end wrench on it for good measure. It is 25MM, the 24MM wrench wouldn't slide over it. That's a beefy sized bar for a small car.
I'm thinking that a 1" sway bar bushing would be okay but on the loose side at 25.4MM. To those who have used the Energy Suspension poly bushings, were they "loose"?
QuickRick
Old Apr 8, 2011 | 11:06 PM
QuickRick's Avatar
Prothane bushings 25 MM
Guys and Gals,
I ordered some Prothane sway bushings for our HHR. I chose these for a few reasons: They have the correct bolt pattern, aren't rubber, are not a universal size but rather 25MM and I did not want the kind you re-grease (but they come with a tube of grease made for them)
It is the great experiment, but I want the clunk to go away really bad. I'm pessimistic that the fix is really as easy as the sway ends and the links but hey....will be great if so! I hope to get them on ASAP.
QuickRick
Snoopy
12
Nov 27, 2014 11:05 PM
1970judge
7
Jun 11, 2014 02:15 PM
alexrckid
Maintenance and Upkeep
Oct 27, 2011 08:34 PM
MWG2
Mar 18, 2009 01:25 AM
