pedders spring rattle
If you no longer have them, you can either buy new ones or, as an old thread suggests, make your own. Thin foam or rubber will do it.
I posted earlier about the Pedders springs. I found mine to be coil binding pretty bad. New upper mounts, with top spring end aligned with upper spring seat tab, seems to cure it. Found neither side were aligned correctly, at spring install, the first time. "Moon"
to the forum badflt!
