Question for the Brembo upgrade guys.
Old Mar 19, 2014 | 10:22 PM
jczboy's Avatar
When I did mine, I did reuse the bolts.
Old Mar 20, 2014 | 07:54 AM
LT1GMC's Avatar
No problem, just trying to get the best info out. Its always easier after some others pioneered the way. I appreciate all the info others supplied to make it an easy swap for me. Part of the problem is many dealers do not research enough and guys end up with the wrong parts. Thats part of why i did the Brembo's, my dealer, using my VIN, got me the wrong brake pads(Brembo ones) so when I saw I needed new rotors anyway, went ahead and swapped. Big Difference!
Originally Posted by pbatmen
LT1GMC, you are correct, they do have diffrent hoses, I got confused because its been almost a couple of years when I did my swap. Sorry about the confusion, there was no write up on how to do the swap when I did mine.
Old Mar 20, 2014 | 07:57 AM
LT1GMC's Avatar
Guys, when I bought new SS spec brake hoses from the dealer (GM 25954272) they came with new bolts and washers if you decide to go that route. They were like in the low $20 each range.
Old Mar 21, 2014 | 01:23 PM
pbatmen's Avatar
Originally Posted by Nightwalkerhemi
I want to do this too,better brakes are always good.
Didn't know there was a write up going to check on it now,only had the hhr for a week the list keeps growing no thanks too the forums:-)
Hey Nightwalker,
Welcome, and check out this thread for the Brembo upgrade.
https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/brembos-up-front-disc-rear-06-2lt-41839/
Old Mar 21, 2014 | 03:49 PM
Nightwalkerhemi's Avatar
Hey Nightwalker,
https://www.chevyhhr.net/forums/showthread.php?t=41839
Just checked it out thanks read the whole post and it seems like a great upgrade for the price and sounds very simple,thanks for the thread link.I have a auto but now i can have brembos thanks too the forum.My fronts already have a small wobble.
Old Apr 17, 2014 | 04:24 PM
bpb355's Avatar
So i went ahead and installed the brembos. I just got them in and they went in pretty easy. I bought new screws but to tell you the truth I bet the stock ones would fit they looked like they had plant of bit, but since I bought the new one in they went. The only snag I hit was when i was trying to bleed the brembo calipers. I was using a one man bleeder pump. It worked great on the OEM rears, but not so much for the brembo's. I guess not enough pressure. Once I got a helper to pump the pedal, they purged just fine. The OEM rims fit with no issues. Overall a pretty easy project.
Old Apr 20, 2014 | 10:53 PM
1970judge's Avatar
Just to help me understand, will the CED upgrade package work for the Non-ss HHR/SS HHR? Looking to upgrade my LT to brembo..
AJL08SS
Dec 16, 2013 03:11 PM
audioman
26
Dec 7, 2013 08:59 PM
RobSSTurbo
Tires & Wheels
Apr 10, 2012 01:51 PM
RobSSTurbo
Racing Discussion
Apr 5, 2012 07:49 AM
coreycooper
21
Dec 18, 2010 11:39 AM
