Rear springs
Old Jun 30, 2011 | 05:47 AM
-md- HHR's Avatar
I'm currently rolling around on front and rear SS/SC springs. The rear is a little to soft, and is slightly higher than the front. I rolled around on SS/SC rears and stock fronts for a day, and it had reverse rack.
I have SS/TC springs, and will be comparing them hopefully this weekend.
Old Jun 30, 2011 | 07:15 AM
hhrfreek's Avatar
Originally Posted by SHADOW(IN)
Put them on the bottom of the springs They fit down in the cup alot easier Jegs makes a U coilspring spacer that works great . )
it's what I used to raise the rear of mine . )
Shadow, what springs did you install in the rear?
Sleeper-
Did your TC springs level you out or are you slightly higher or lower? Can you recall how much more sag occurred? I'm not concerned I like the look and feel a lot more j/w. Just wondering how the results have varied so much, but I guess a full tank of gas would even give you different numbers.
Old Jun 30, 2011 | 11:35 PM
Originally Posted by hhrfreek
Sleeper-
hhrfreek-
I'm almost perfectly level (just a tad higher in rear) , initial drop was 1", couple yrs later, 1-3/16" drop. (so sag was only 3/16" to date) a sign of a good quality spring imo.. This was checked (each time) with about the same amount of gas & tools on board. I'm kinda fussy that way..
The ride is fine & I haul stuff, so that is cool too. I did not cut the bump stops & have never bottomed out.
What results are so varied you speak about ??
Old Jul 1, 2011 | 01:14 AM
hhrfreek's Avatar
It sounds like others in this thread stated they sit lower in the back. Do the SC springs sit lower than the TC?
Anywho... I got in a good night of thrashing the HHR and the suspension feels really good. I am very pleased with the new springs/shocks. Way bigger difference than the TTR sway bar I put on a week ago. Still a fair amount of understeer on hard corners, but the new rubber will be here next week and I think that will put a stop to it.
hhrfreek's Avatar
Old Jul 1, 2011 | 01:26 AM
Yes the SC springs are softer & sit lower, my Bud has them & his dropped 1-1/2" after install.. Before sag. He likes the extra soft ride, but to me it looks too low in rear.
I agree with you, Springs made a Bigger diff than my 1" rear sway bar.
mine is the FE3 set-up, so I just changed springs to TC.
Yes better tires is a big help also, some day I'll get some..
Cool that you're digging the TC springs.. I sure am pleased with mine..
Old Jul 1, 2011 | 03:11 AM
SHADOW(IN)'s Avatar
Sleeper-
I kept the stock springs I just put the U ring spacer under them to raise the rear of mine 1 inch to give it a nice rake. haven't noticed any real differance.
I did catch a judge at a show looking under my ride & asking is this rear wheel drive ?
Just wanted to tell you if you were going to use spacers to use the rings and not the little blocks you shove in the springs ( they can damage your springs over time )
Old Jul 1, 2011 | 11:46 PM
SHADOW(IN)-
It seems to me, you have some confusion about adding TC springs, they lower the ride.. Just rite imo..
Old Jul 2, 2011 | 02:33 AM
SHADOW(IN)'s Avatar
Originally Posted by sleeper
SHADOW(IN)-
It wouldn't be the first time I was confused about a Mod someone was doing . )
Old Jul 3, 2011 | 01:16 AM
You are not alone, don't sweat the small stuff..
