Rear sway bars - SS, Progressive?
Hi Folks, Forgive my ignorance, but does an HHR SS have a bolt-on rear sway bar in addition to the twist rear axle beam setup? If there is an SS bar, is it weaker than the Progressive bar? In aftermarket, is the Progressive bar the weakest of the bunch? Many thanks, and God Bless, Marc
& the "Hard-Core Bar" doesn't tuck up into the rear axle as well either...
I'd say the mildest one would be the Pro-Tech (at least it's the thinnest OD bar made).
I installed my TTR bar a couple weeks ago. It was very simple! It took longer to jack the damn car up and get it on jack-stands than it did to install the sway bar. There are excellent instructions posted by "405HP_Z06" here: https://www.chevyhhr.net/forums/show...&postcount=141
(thanks 405HP_Z06)!!!
The sway-bar is a great mod! Took the SS on the twisty, recently paved logging road from Mesachie Lake to Port Renfrew on the weekend. Had an absolute blast through all the twisty corners!!
