Replacing sway bar
Replacing sway bar
Got 2007 hhr 2LT and have a bent sway bar on the passenger side . It has been rubbing on the top of the control arm .. so I’m getting one from the boneyard and replace it so my question is I read you have to loosen the cradle bolts and support it so you can get it out .. and are the bolts accessible under the car ? are there any torque specs on tighten them up ?
i bought the car with 110000 miles and found out it was rubbing on the top of the control arms when I going to change them out rear bushings are bad .. the car has got 175000 on it now .. this is happening on the passenger side ..
If you remove the steering rack, it comes out the driver’s side you can remove the swaybar, it comes out the passenger side. You will have to remove the rear transmission mount.
Are you sure it’s bent? Did somebody install the end links in the wrong side?
could you post a photo?
That had to be a big accident! I would get the alignment checked, might need a body pull. The only way I can think of to bend the sway bar is to really bend up the LCA an strut, the strut geometry is determined by the wheel well mounting point.
10 inch is really 9.86 inch.
It obviously has to come out anyway. Before you buy a new one, once you have it out, you could evaluate and see how hard it would be to bend it back into shape. Depending on how it’s bad it is, it might not be that difficult to correct. I guess it would still be easier to just replace it though.
im trying to add pics and I did uploaded them put how do you post them
Here’s a pic
