soltice/skye wheels
Do they not clear in-board otherwise ?
An offset of zero means the mounting surface of the wheel is on the centerline. A postive offset means the mounting surface is more toward the outside of the wheel, which brings the edge inwards. The stock HHR wheels are 42mm offset, while the solstice wheels are 55mm. That would mean the wheels might interfere on the inner side and would be farther in under the fender. Adding a spacer would correct this.
Play with this calculator a bit and you will see: http://www.bigcustomwheels.com/info_specs.jsp
