Spring settling timeframe
Old Jul 10, 2013 | 02:11 PM
Dracos's Avatar
I'm probably going to swap on some Cobalt SS/TC rear springs soon. Every thread about spring swaps says to give them 30 days to settle, but is that real calendar time, or an approximation based on typical mileage? I ask because I genraally only put on about 150 miles a month. Yes, you read that right.
Also, will I have any issues if I have a TTR rear sway bar put on with the springs?
Old Jul 10, 2013 | 02:54 PM
Settling is just a term to describe the springs getting firmly seated in the perch area. The springs themselves may or may not settle a slight bit. 100 miles or so, and a few good bumps and they're usually settled in.
I measured mine numerous times after swapping springs. Never noticed much settling at all after a few thousand miles. 1/8" at the most.
Adding a swaybar will not affect the springs. Only make it handle a little better.
Old Jul 11, 2013 | 01:47 AM
Dracos-
I have that exact set up on my '08, SS/TC + TTR. (you'll dig it)..
Good springs seem to take longer to settle, imo..
Springs dropped 1" after install. Took about 500 miles to settle in at 1-1/4" which has been at that level for well over 3 years now.. But I haul stuff too.
Old Jul 11, 2013 | 02:37 AM
07azhhr's Avatar
Originally Posted by sleeper
Dracos-
Wow it dropped that much with those? I thought I read only 3/4 but heck 1-1 1/4 is more prefered . I see Rockauto is $130 something before shipping for all four corners. Has anyone found cheaper or is that the best pricing currently?
Old Jul 11, 2013 | 02:45 AM
I think the springs will be a great addition but would rethink the TTR sway bar. There are others that work immensely better. That is on my SS, I have not felt the need for a bar on the 2lt, the YYZv1 springs have no roll even with fe3 struts and shocks.
Old Jul 11, 2013 | 12:33 PM
Dracos's Avatar
I ordered the SS/TC springs and the TTR bar last night. The main reason for the springs is aesthetic, to drop the back end.
Old Jul 11, 2013 | 10:06 PM
07azhhr-
Yes it dropped it 1-1/4" in rear. Try GMParts Direct, IIRC I paid $70. delivered, probably cheaper now (but that was just rears)... Or look on Cobalt SS site for used. They always seem to be selling some sets.
Dracos-
Cool, the springs do more than just look better, getting the rear a bit lower made a BIG diff on mine in handling.
Wait till springs settle before you re-adjust the headlights.. One time & good.
I put the TTR bar on a month later, & was very pleased at the improvement on cornering, etc.
Old Jul 11, 2013 | 10:45 PM
Dracos's Avatar
Dracos-
$31.93 each plus $16.60 shipping at gmpartsdirect.com.
I never adjusted my headlights after I put my Depos in a year ago, still need to do that.
I'll probably do the springs and bar all at once.
Old Jul 11, 2013 | 10:55 PM
That'll work fine.. I purposely did the springs first, to judge the diff.. Then later the Bar.. Both had made noticable positive improvements.
Good combo.. I used Loctite on the Bar bolt threads, they stay tight now..
PS: Don't forget to unbolt the rear brake line fastener from rear axle beam before you hang it, to drop the springs. It's not long enough to travel all the way down.
Old Jul 11, 2013 | 11:33 PM
Dracos's Avatar
I won't be doing it myself, I already talked to a shop about having it done.
