Well worth the time and effort!!!!
Just finished upgrading the brakes on my 2010 LT. Thanks for the info in this thread. The swap went without a hitch.
If I do Brembo brake will my stock spare tire fit the front? Thanks
Originally Posted by 09BLACKHHR
(Post 776324)
(Post 776325)
No.
I believe the SS owners with the Brembo's have to change the rear wheel to the front flat and put the spare on the rear!
Originally Posted by Oldblue
(Post 776332)
(Post 776332)
Removing the Flat Tire and Installing the Spare Tire (SS Model) The SS Model has larger performance brakes than the Base Model. The compact spare tire will not clear the front brakes. Do not use the compact spare tire in the event of a front flat tire. You must use the rear tire to replace the front flat tire. I know some of you guys run 16's after doing this SS rotor conversion, but I wonder if anyone has checked to see if the compact spare will fit up front ? The spare rim being thinner and a different design,,,well, it just makes we curious. I would hate for someone to suffer a flat and find out the hard way that the compact spare won't clear the "new" brake setup. Maybe someone should clarify this or try it. |
I have the non Brembo SS 11.65 inch brakes and the 16 inch steelies fit, but the spare tire doesn't fit, I'll have to do the front to rear swap if I get a flat!
Wow I can't believe it ok thanks for the info
| All times are GMT -5. The time now is 04:57 AM. |
