Sway Bar Bushings
Old Apr 10, 2013 | 11:42 PM
Originally Posted by VinceP
Try Energy Suspension 9-5161 or 9.5161 as a part number. If I remember correctly that is the ones I used.
Hey, thanks guy - that really helps.
Old Apr 11, 2013 | 09:13 PM
alexrckid's Avatar
http://www.energysuspensionparts.com...sp?prod=9.5161
http://www.partspro.com/catalogpg/20...ion226-228.pdf
Old May 16, 2013 | 01:33 AM
cornwalis's Avatar
Does moog not make. Sume or movtech
Old May 16, 2013 | 09:29 AM
thaanks for the link, I just ordered a set of these bushings, my originals are worn out after 212,600 klms
Old May 16, 2013 | 12:53 PM
alexrckid's Avatar
216 ++.....like the energizer rabbit..........gotta love these HHR's....i sure do.
Old May 17, 2013 | 09:11 AM
pbatmen's Avatar
I just replaced mine on Sunday, with a set from ebay, same as the ones I replaced a couple of years ago that I picked up at the chevy dealership, the were like 15 bucks shipped and OEM.
Old May 17, 2013 | 08:51 PM
I picked up the recommeded set today at autozone (were in-stock), and will hopefully get them installed shortly (which means within the next couple of months) :)
Will be great to get rid of the thunking on small bumps.
Thanks VinceP.
Old May 18, 2013 | 04:21 PM
VinceP's Avatar
Thanks VinceP.
Glad I could pass the info along. I believe I got the info from someone here.
Have had mine in about 6 months or so I guess and no issues.
Old May 19, 2013 | 09:26 PM
alexrckid's Avatar
Thanks VinceP.
only thing that i did when i swapped to the energy suspension bar mounts was to install 90 degree zerk fittings rather than the "zero" degree supplied fittings. with them twisted at the proper angle, makes greasing them a breeze(behind the front tires).....i "locked" the fittings at the right angle with some jb weld...........
Old May 20, 2013 | 12:42 AM
GOod tip on the zerks - I was planning on checking that out to see if it would be worthwhile. Red loctite would probably also work to lock them in place - but I am not sure how it would react with the bushings themselves, as loctite can be pretty nasty to paint and some plastics. Great tip though. :)
