Uneven Brake Pad Wear
Old Mar 17, 2024 | 04:22 PM
SuKi's Avatar
Yesterday I got a nasty sound when braking from the front passenger wheel two turns away from the house. I've got 186k miles on the car and about 30k on these rotors and ceramic pads. Today, I popped off the culprit wheel and found a very worn inner brake pad. I replaced both pads, but was wondering if anyone might have any ideas as to why. I did notice as I was compressing the passenger caliper piston, the side with uneven wear, that the piston boot did not seat flush inside of the caliper. Attached are what the pads looked like. Any idea's on why this may be happening. It may be time to do the non-Brembo SS brakes up front.
Old Mar 17, 2024 | 04:40 PM
The inner pad usually wears more than the outer Because the inner tends to drag on the rotor, the only form of return spring is the square cut O-rings in the cylinders
The slide pins need to be lubed. The rear brakes need to be kept manually adjusted.
Old Mar 17, 2024 | 08:44 PM
Maybe a brake fluid flush would help, that one inside pad side is way different that other inner..
Old Mar 17, 2024 | 09:03 PM
greg8453's Avatar
A flush will do nothing for this. Lube the slide pins
Old Mar 18, 2024 | 08:40 AM
Better yet install new slide pins kit, the OEM are 13 years old, worn and pitted
Old Mar 18, 2024 | 12:14 PM
greg8453's Avatar
Hoot man.
Old Mar 18, 2024 | 03:54 PM
It also cleared up a slight thunk noise on my right front.
Old Mar 18, 2024 | 08:34 PM
And the brake fluid should be changed at this age as well..
Old Apr 8, 2024 | 02:04 AM
SuKi's Avatar
New slide pins and all lubed up. We'll see what the next few months holds in store. Thanks all for the comments.
working on it
14
Aug 5, 2022 03:40 PM
chaosdsm
Jun 1, 2022 12:37 PM
MikeRuth
Jul 11, 2014 06:06 PM
blacky
Jul 11, 2013 06:02 PM
MajorSpittle
Mar 11, 2011 05:09 PM
