Warped Rotors
Well like i said there is a VERY noticeable difference in braking with these ROTORS and Pads. And you say as they get hotter the braking is worse well in everyday driving I think with the Ceramic pads it stops better when they are some what hotter, im not talking about auto Xing. And yes i did test them with my stock rotors on because they sent me an extra set that is supposed to cut down on sound.(I thought i had a problem because the sound didn't go away but this is the nature of the pads so i put the stocker back on just in case they wanted the EBC rotors sent back to them) so before i put my EBC rotors back on i tried them on the crap GM rotors and the stopping power is no where near what i get with the EBC rotors. Also once again the shimmy was there with the stock rotors.
Why do they put drilled and slotted rotors on all these high end fast cars like the ZR1, i mean they should just throw some good pads and then just the standard Solid rotors on them. from what your saying it will be the same. I just don't get what your saying i mean why do racers that race in auto cross type track use slotted and or drilled/dimpled rotors if they don't help performance at all. Somebody in the Brake industry has something all wrong and they shouldn't be making slotted, dimpled/drilled rotors because they offer no performance value only looks. Also i have the red pads and for street they are just fine and i use them for only street.
This is all my opinion im not trying to start a fight, the only reason I am stating my opinion is because i own a HHR and i know how much of a difference these do make on the HHR. If you want good stopping power for our cars go with these pads and rotors you will be very impressed by the quality and performance from them.
Here is what is posted on Wilwoods tech site.
Why are some rotors drilled or slotted?
Rotors are drilled to reduce rotating weight, an issue near and dear to racers searching for ways to minimize unsprung weight. Drilling diminishes a rotor's durability and cooling capacity.
Slots or grooves in rotor faces are partly a carryover from the days of asbestos pads. Asbestos and other organic pads were prone to "glazing" and the slots tended to help "scrape or de-glaze" them. Drilling and slotting rotors has become popular in street applications for their pure aesthetic value. Wilwood has a large selection of drilled and slotted rotors for a wide range of applications.
This should answer your questions.
This is much of what EBC, Hawk, Stainless Steel Brakes and other have or will tell you.
I also have dug up the info from racers and what their pro's and con'c are. Most of what they have to say will back up what the MFG preach.
All I am trying to do here is give out some correct information that is not some seat of the pants observation. I work with these companies and when they are truthful on their products the word needs to get out.
With the web and forums a lot of good info get passed but also we get a lot of inaccurate info passed around till it become true.
You have every right to your opinion and I do not begrudge that in any way but make sure you understand all the facts. It is times like this people start to believe things like the Tornado, SplitFired plugs and electric superchargers really work.
I am lucky to work with a lot of tech deparments in the performance aftermarkets. I also get to meet and deal with the staffs of many of the compainies. I see and hear what the truth is and just try to pass it along. If it saves someone a lot of money or fixes the problem that is a win for all of us.
The bottom line is EBC pads are what make a differance and they work so I will brag on them all day. Now the Rotors are fine if you can afford them and understand there is little to gain with them. There is some small benifits bu it is more estetics than anything.
If you want to believe the facts or not or If you want to disagree I can give you Willwoods or EBC number so you can tell them your observations.
I just want to make sure people understand what the MFG claim on their own products and make smart buy when changing parts on their cars. The better the public is informed the easier my job is.
You should hears some of the crap people believe that is false.
Excellent information, but one thing I would keep in mind is that surface area helps with disipating heat. That is why heatsinks have fins. So, by having dimples and slots drilled in the rotor, you are increasing the surface area.
Also, according to the website, the yellow pads are for racing and the red are for 'faster street driving'.
I say this because I just got my rotors and red pads and am waiting for a day to install them when it is not 99 degrees outside.
As for the dimples they acocunt for so little suface area they should not matter. Also you have the trade off as there is less material to absorb the heat too. There again it is so little it really makes little differance.
The fins inside the front rotors do more heat release than anything. Since the rear brakes do so little of the stopping they leave them off to save weight and I am sure some money too. The rear temps really stay low on most cars.
I am sure you will like your new pads. Do make sure to follow the bedding instructions. Also they will makes some noise at first. Once they seat in you will see better perfromance and the noise will go away.
Also if you do not already use it look for Sil Glyde brake lube to lube the slide points on the caliper. This is great high temp stuff and it works very well.
Too many people fail to lub and clean the caliper slide points and end up with a inside brake rubbing till it wears our prematurely.
I already bought a container of some synthetic brake lube that is supposed to be great (cost almost 20 bucks so it better be). As for brake in, all the instructions say is to avoid hard stops for the first 300 miles. Are there more specific steps I should be aware of?
They will be bedded in pretty well by 300 miles.
Any noise, grip and any other issues associated with new pads should be gone by 1000 miles.
The most important part is the first 300-500 miles as you just need to drive normal and try to refrain from any hard stops. This time allows the pads to become geometrically matched to the rotos.
You also will get extra dust in the first 300 miles as they Brake-In material will leave some extra dust.
EBC states "Divers Must be Patient"
You should be ok with the synthetic lub.
I had trouble with brakes on my Sonoma for years and once I went to EBC they have been great ever since. Better stopping no warping, no noise, little dust and better wear. I have the ZQ8 suspension on it and even auto cross it. I wish I had know about these pads sooner.
Hope this helps.
Who said use lube on the pads?
The slide pins and on any other moving suface on a floating caliper that lets it slide needs to be addressed.
I have done brakes on many different cars and trucks and all usally have points that need cleaned and lubed. But at no time lube should it ever come in contact with the pad material or rotor surface.
I have not done a HHR yet but I assume they also have these points that need addressed.
I do agree the pads should make a big improvment.
If it is a small warpage you can take a light cut to true them up. But cut as little off as needed.
And keep in mind that they are thin to begin with and prone to warping. So cutting them will only be a temporary fix. Sooner or later you will have to have them replaced, then you can either go with factory that are still thin and will keep warping or going aftermarket to something meatier that will last.
