Wheel shift
Old Aug 15, 2023 | 01:38 PM
BrindleBully's Avatar
Wheel shift
Hello I could really use some Help figuring out cause of the feeling of wheel shift during a turn on my wife's 06 Hhr lt. She has had it for a few years now & the front suspension components have been just a bit of a constant problem. I have had to replace the bushings, ball joints, control arms just about ever year & a half. Well just 2 months ago the lower control arms, bushings, & ball joints were replaced again. But the other day my wife said the front passenger wheel was making a noise on the way home from work. I asked what type of noise,& she said she just couldn't even describe it. So I took it for a test drive and it of course didn't make a sound at all. I drove it around turns and got it up to freeway speeds nothing. Then when I get back to our apartment and I am turning into the parking space the entire front end felt like it shifted to the outside direction of the turn. And I could hear and feel the tire rubbing on the fender well. I straightened out the wheels. Checked to make sure the wheel & lug nuts were tight. The only thing I found to be really loose was the tri joint of the axle. It has way more play than it should. But that shouldn't cause the wheel to shift into the well like it did , right?
Old Aug 15, 2023 | 01:43 PM
Look closely at the lower control arm rear bushings
The bottom one is toast!
Old Aug 15, 2023 | 04:09 PM
Here is a link
Old Aug 19, 2023 | 02:20 PM
Changed both of the lower control arms and both rear & front control arm bushings on both sides. However I did already check to see if something was wrong with the bushings. They are fine. Today I am changing the struts, strut mounts, & springs on both sides. As well as both axles just to be safe. Thanks for trying to help. I'll post again if the problem stops after install of the parts today.
Old Aug 19, 2023 | 02:48 PM
I don't see a mention of hubs/bearings. the end play is less than .005 inc, if you can feel any they are bad. That sound is most likely from hubs.
Old Aug 20, 2023 | 08:12 PM
PulpFriction's Avatar
I wonder if you could expand a bit on exactly what that means.
Chrris F
Jul 24, 2019 09:57 PM
Bkspring
Apr 4, 2019 05:45 PM
drummerboy0088
10
Jun 13, 2017 05:50 PM
cincy513
Dec 11, 2016 10:39 PM
FLORIDA
Jan 22, 2012 08:28 PM
