Wheel Studs
Old Sep 4, 2009 | 02:31 PM
traketo's Avatar
Wheel Studs
I broke one of my wheel studs on my 2009 HHR SS and was wondering if anybody know how to change wheel studs?
Thanks
Old Sep 5, 2009 | 10:33 AM
an08HHR's Avatar
Did one on an Impala 5-6 yrs ago. I removed the caliper and rotor then used a socket which was larger in dia than the base of the the broken stud so it would clear, then used a big C clamp to push it out with an occasional rap with a hammer.
Old Sep 5, 2009 | 11:27 AM
Sno White's Avatar
Shouldn't this be under warranty? I hate when people say that!
Or, did you do a BAD?
Old Sep 7, 2009 | 12:13 PM
traketo's Avatar
The dealer I went to said that wheel studs are not under warranty. The studs are only like $6 but labor is like $166!!
Old Sep 7, 2009 | 12:23 PM
harleysshhr's Avatar
you can safely get by with four. so wait until you put brakes on and change it out then. $166 is about three time what it should cost.
Old Sep 7, 2009 | 12:46 PM
Sno White's Avatar
Agreed, I ran a Ranger for years with only 4 out of five. Plan was to take care of it when I did the brakes. I knew about the problem and I kept an eye on it. Plus on that vehicle if another lug was to come off the hub cap would have left the vehicle long before giving me a warning.
EDIT I've reconsidered my comment about running with only 4 lugs. If the vehicle brakes are under warranty then the fact that only 4 are present, it seems to me the dealer could use that as a way to decline a claim for warped rotors. Something people have reported having problems with. I never had any problems with the brakes on the Ranger.
Old Sep 7, 2009 | 11:35 PM
IgottaWoody's Avatar
Yes 4 bolts can cause warping from uneven torquing of the hub/rotor...
Old Sep 8, 2009 | 12:31 AM
I agree, improperly torqued wheels can add to warping of rotors. Maybe not the cause but an added factor. Heat is the number one cause. Also, one could say that missing a lug the vehicle's carrying capacity is lessened. Also true but not usally a factor. Having ALL the lug nuts is the ideal scenario. Having not to spent $166 is probably a better state of affairs.
Old Sep 8, 2009 | 07:49 AM
esmarkey's Avatar
I have a hard time believing that the studs are not under warranty, and yes you CAN run on 4, but there is a reason that one broke, and only having 4 puts undue stress on the remaining studs as well as potential for warping rotors as others have mentioned. I would contact another dealer, or at least ask to speak to the service manager and then general manager if the service manager is not willing to do something.
A SS is a high performance car with features like launch control, so unless you were off-roading or something like that, a broken stud is a valid warranty issue.
Old Sep 8, 2009 | 07:59 AM
solman98's Avatar
Just replace the stud. Tap it out and take it to Advance or the Zone and match it up. Not sure ir they will have them listed yet or not. So a stud in hand may be helpful. They are not hard to change. You can use a open ended lug nut to reseat the new stud.
$166 is crazy for the amount of work it actually is. New stud and open ended lug nut may set you back $5..... Probably about $3.
