Can you identify this transmission part? Please help!
Old Sep 4, 2022 | 08:05 PM
MunKy_x's Avatar
[SOLVED] - It was just a spring that was in the seal that got pushed out when I put the cover back on.
2008 Chevy HHR LT 2.2L - 4T45-E Transmission
I really need someone's help on identifying this 4T45-E transmission part and where I might be able to find a new one. I was replacing the solenoids in my transmission by taking off the side cover and I got them all switched out. I was tightening the side cover bolts down and I heard a pop that sounded like something hit the side cover and when I went to check the axle seal I seen this (the picture is below). I have no idea where this came from. I seen this video on YouTube:
It looks like the part he takes off at 8:39, but he doesn't talk much about it (I thought he called it a latch); also the transmission worked on was a 4T40-E It looks like a spring to me. Any help would be appreciated. Thanks.
Old Sep 4, 2022 | 08:29 PM
That is not it. It is called "manual valve link.
#802 here:
Old Sep 4, 2022 | 09:16 PM
greg8453's Avatar
Take your cover back off.
Old Sep 4, 2022 | 09:22 PM
Your seal is mispositioned also.
Old Sep 4, 2022 | 09:26 PM
MunKy_x's Avatar
I'm going to, but I'd like to reorder the part first because it looks like a spring, so I'm sure it's ruined.
Old Sep 4, 2022 | 09:29 PM
And the link is nowhere near the Axle seal, so it doesn't seem like it would be that.
Old Sep 4, 2022 | 09:33 PM
MunKy_x's Avatar
#802 here:
Thanks. It seems like the manual valve link is solid, but what is stuck is a spring?
Old Sep 4, 2022 | 09:35 PM
MunKy_x's Avatar
Old Sep 4, 2022 | 09:46 PM
Maybe you should watch video for the transmission you're actually working on. If you take the cover off, we can see the part better, and be better able to identify it.
Old Sep 5, 2022 | 08:44 AM
greg8453's Avatar
Your seal is bad and needs to be replaced.
