HHR trans interchange ?
My 2006 HHR has 228,000 miles on the clock. It still runs great, and I really like the car, but the trans is starting to give up. Question is, what other year, HHR, or any other GM car's transmissions will interchange ? And will the engine size matter. I'm going on the hunt for a trans, from the local DIY salvage yards. It's a 4T45E.
It is usually does ok when cold, but after warmed up, when put in drive, from park or reverse, there is a delay going into low, and some times I have to feather the throttle to get it to engage low gear. From searching these symptoms, it seams the low roller clutch may be starting to fail. I thought about getting another trans, and rebuilding it, then just swap out. Never done a 4T45E before, but the schematics I've been looking at doesn't look too bad. No worse than a 700 R4, and I've did a few of them.
HHR*Chevrolady
7
Sep 11, 2010 03:18 PM
