Ky clutch is ordered!
Are you guys replacing the OEM flywheel? I am trying to find a place to install my KY Stage 3, but I have a couple of places telling me (sight unseen) that I should replace the flywheel, not resurface. Any thoughts?
I haven't found many good shops. The $1700 was RPM Automotive here in Jax. Called the dealer, they'll do it for $900, which is better. I was hoping for ~$600.
Another note, based on your recommendation, I'll pick up a new OEM flywheel from GMPartsDirect prior to the install and have it thrown in too.
I might just do that. You getting it done over at Lashaway?
Once you get it put in, let me know how things go. I need about 3 weeks to get the rest of the funds together, but I may get you to give me a recommendation then.
