Some Fun for the Day, No Clutch Driving Home from Parkland
Old Aug 15, 2014 | 03:19 PM
cj krause's Avatar
Well interesting day at Parkland. Clutch started slipping real bad on the way there. A long time ago i noticed the clutch smelling after a lil fun just after i bought it and car had 30,000 miles on it then so i knew i would need it sooner or later
started back and it started chattering and then it just went out as i got on the freeway. so i drove it from parkland all the way home w no clutch and just used the gas to slip it in gears. around 25 miles w no clutch to get home.
went thru a strip mall parking lot to avoid a light and get home and got it in 3rd gear and made it home thru the Sachse area using 3rd gear till i got into my driveway and got it in neutral so we can tow it to Brandons to get it replaced.
Will take a lil while to get the money to order the Clutchmaster Stage 3 clutch and parts. Around a $1000 total so get it installed.
Old Aug 17, 2014 | 07:11 AM
fastsuv's Avatar
If the cluch was shot, how did you drive it at all? Wasn't it slipping badly?
I drove a friend's car home years ago without using the clutch when his clutch cable broke, but the clutch itself was good. It was a small car and you could start it in gear, so I used the starter to get going the few times I had to stop.
Once in a while, I practice no-clutch-pedal shifting using rev matching in my HHR for fun. If you match revs it's as smooth as using the clutch.
Steve
Old Aug 17, 2014 | 08:05 AM
LawDog88's Avatar
Fastsuv, I believe that's what he was talking about is using the RPM's to shift. I have practiced this in my HHR as I had my clutch go out on my 1LT 2.2 approx 30k miles ago.. No fun when you are trying to accelerate and next thing you know, you can't.
GulfShores
Mar 28, 2015 09:23 PM
tracy waddell
South Pacific
Nov 28, 2011 07:59 PM
AaronSS
Sep 9, 2008 10:09 AM
k9t8m
Mid Central
13
May 4, 2008 07:51 AM
Kwhopper89
Aug 16, 2006 08:13 PM
