Who makes the best replacement CV axles?
Old Apr 23, 2022 | 07:57 AM
Originally Posted by Hvymax
So I only have one recommendation for the Rock Auto products. I'm shocked that the ecotech community hasn't come up with something better or stronger considering what these engine's are capable of. "I've found the cost of better parts is less than 25% the cost of doing it twice!!! "Not to mention downtime, towing etc!
Not sure what you are saying here. In fact, I read it several times. Seems like something got left out of your post......maybe ?
The part above, in blue. No clue on what that means.
Old Apr 23, 2022 | 08:40 AM
RockAuto is a website like Amazon, they produce no products.
I have never heard of an axle breaking under normal use. Ball bearings wear out.
Old Apr 23, 2022 | 08:54 AM
Detroit axle is a rebuilder, contact them for your custom axles!
Old Apr 23, 2022 | 10:31 PM
Hvymax's Avatar
Spending the extra for ARP bolts, Double Diamond gears etc more than pays off in longevity and ability to withstand many times anything originally intended. My recent plans for any engine builds will be an 8.5 compression blower motor. It will run all day on regular pump gas and easily handle periodic full blown nitrous hits or other random idiocy. All of the extra cost is easily made up for in general longevity and a usability.
Old Apr 25, 2022 | 05:35 AM
geg's Avatar
geg
Originally Posted by mongo
It is possible, but for some reason the CV joints themselves cost almost as much as the axle assembly.
is there a part number? maybe a couple from different manufacturers?
I want to look for it nearby
don't forget, I have a high shipping cost, so the final price of a bare CV joint can be much lower
Old Apr 25, 2022 | 07:28 AM
Hvymax's Avatar
I see that ZZP sells stage 1 performance axles. Anyone use them or something similar? I'm only going with a few inches of lift but I want something that won't be stressed.
Old Apr 25, 2022 | 08:34 AM
SS axles are different won’t fit LS/LT
Old Apr 25, 2022 | 08:59 AM
Their LNF axles(which are currently sold out) are for the SS. They won't fit your car.
Their 2.2/2.4 axles are for manual transmission only.
Their LSJ axles, I don't know, probably won't work, but you could nose around the Cobalt SS forums to see if it's been done.
Old Apr 25, 2022 | 09:41 AM
Hub end is different for the LSJ different spline count!
Old Apr 30, 2022 | 09:59 AM
PulpFriction's Avatar
I can't help thinking that it would be better to use your energy to work on other things and unless they are already broken, solve the axle problem once it proves to actually exist.
