(Post 924451)
I can't help thinking that it would be better to use your energy to work on other things and unless they are already broken, solve the axle problem once it proves to actually exist.
For struts and shocks, KYB!
for brakes PowerStop and upgrade to the SS non Brembo 11.6 inch rotors! |
Originally Posted by Oldblue
(Post 924457)
KYB aren’t coil overs, they are struts and shocks, I’ve put 230,000 miles on a set , no leaks no bouncy suspension, I just swapped them out because they were 10 years old!
The front caliper brackets need to be changed for the 11.6 inch rotors, so you might as well do the conversion, you’ll be happy you did, just order for 2008 SS front brakes! |
Like I said a while back; I recommend getting rebuilt axles from Autozone/Advance/ PepBoys/O'reilly. I have had better experience with rebuilt than new ones, not much cheaper.
Originally Posted by donbrew
(Post 924465)
I have never heard of one breaking, not even from the drag racing crowd. Ball bearings wear out by their nature. There is only a CV on the outer end the inner is a tri-pot slip joint.
| All times are GMT -5. The time now is 02:52 AM. |
