Will this hurt my trans?
Old Aug 17, 2012 | 06:20 PM
Joshua022's Avatar
To save gas mileage whenever I am going down a hill, or coming up to a stop, I put the car in neutral and let it cost to save on gas.
Will it hurt my trans to continue to do this while driving down the road?
Old Aug 17, 2012 | 06:29 PM
urbexHHR's Avatar
No, it won't hurt anything.
Old Aug 17, 2012 | 06:44 PM
swerv0428's Avatar
It shouldnt hurt the trans. Mine does not like me doing that. If i bump it into nuetral when coasting i get a nasty clunk that can be felt in the car.
Old Aug 17, 2012 | 06:46 PM
Old Lar's Avatar
Part of hypermileage tchniques.
Old Aug 17, 2012 | 06:47 PM
db/sb's Avatar
Going down hill or coasting to a stop, the throttle is closed so how would being in neutral save gas?
Old Aug 17, 2012 | 06:58 PM
urbexHHR's Avatar
On cars of today it really doesn't benefit. It's cars with a carb so there's less load on the engine.
Old Aug 17, 2012 | 07:03 PM
badassbowtie's Avatar
exactly....fuel is cut off when in gear and coasting...neutral will use gas...
Old Aug 17, 2012 | 07:50 PM
Joshua022's Avatar
Doing 2800 rpm while coasting or 800rpm
The throttle blade may be closed while coasting, but it has to take more fuel to keep it at 2800rpm rather than 800.
Old Aug 17, 2012 | 07:54 PM
Breadfan's Avatar
I dunno about that. HHR is pretty good at lean cruise. Fuel is cut for coasting yielding a slight engine braking feel.
Old Aug 17, 2012 | 07:59 PM
Joshua022's Avatar
True it may not be a huge difference. But definetly some, wether its worth it or not I dunno either.
