Mods to improve mpg?
I use my inst-mpg and the boost gauge in conjunction. That been more than enough, I just wanted to suggest a way to get inst-mpg for those with out it. Check cleanmpg or hypermiler for help with those two products.
Interesting hypothesis. And I concur.
But, to the original poster...... If you are asking about mods, add-ons, etc. to increase gas mileage, I would suggest having the ECM REPROGRAMMED for BEST GAS MILEAGE, would be the best bang for the buck (note that performance would probably suffer however).
Maybe JoeR...if he sees this, can confirm or rebuke this. I would consider him the resident "expert" on reprogramming.
I have avoided all the numerous threads (good or bad) about mileage, since I believe that "your mileage may vary" and that the driver, along with sensible maintenance are the biggest factors, let alone all the variances of stop frequency, etc.
Cleveland had a lot of good advice in his post.
The stock intake is VERY efficient. No drop in MAP all the way to redline. It is a true "cold air intake". I sincerely doubt that any of the aftemarket intakes would result in better mileage, let alone power. The old BS standby, the CGS is a HOT air intake, meaning less air density and, guess what? Less volumetric efficiency (less mileage and power). Y'all can believe what you want.
As far as ECM reprogramming is concerned.... First, the areas of any of the tables involved, the areas hit during any "cruise" condition and those of full power demand are totally different. They have absolutely no relation to each other! The good news is that a good tune can optimize both mileage and power.
But the biggest gain I've seen is playing with the "hyper-miling" basics. Primarily, the best gains are in town driving. Let's just say that driving like an old granny, pissin' other drivers off
As for highway cruising, the hyper-miling just doesn't seem to work like it does in stop and go. But my last two trips resulted in mid-35's at average speeds of just over 70. I'm happy!
For better mileage
I have greatly improved my mileage via the following:
1. The final gear shift point minimum speed is 40 MPH.
2. Without risking a ticket, try to drive at 40 minimum.
3. As soon as you have enough acceleration or speed, remove your foot from the gas pedal and very smoothly reapply.
4. Watch carefully the RPMs and the gas mileage, I have a 2008 with real time.
5. You will notice that you can still achieve your target speed with much better mileage by getting the transmission to shift to the highest gear possible (based on your speed) sooner by using this method.
6. This is very noticeable when you hit 40 MPH, be gentle and watch the RPMs drop to about 1500 at 40. Hope this helps.
