'09 Front or Rear Power Outlet Amp Rating?
I thoght about getting an air compressor for bicycle tires, etc., and it says the power outlet plug needs to be at least 15 amps. I can't seem to find the rating stated anywhere including the online manual. Anyone know what the rating is? Thanks, Rick.
I don't know what the raring is but I have used a small automotive air compressor with my 2010 and I have had no problems.
Ron |
I don't know what the rating is either but wouldn't the size of the fuses for those circuits tell you?
Originally Posted by Bertski
(Post 667406)
Good point, makes sense. Thanks for the replies. |
Its a 15 amp fuse, but I think you could shove a twenty in there., or tap the battery with some alligator clips
Rick- X2, 15 amp. I do have & use a compact air compressor for auto tires, works great & no problems.
Got it at auto parts, bout $14. |
Thanks, both. I was considering another that has alligator clips. I do have one now with the fitting that clamps onto the valve stem which can be a little troublesome. the other two screw on. On the other hand, the one I have can be set to shut off at a set psi. I guess I'd be smarter to just save my money.
Look at this thread https://www.chevyhhr.net/forums/general-hhr-4/panel-rear-power-outlet-same-power-plug-36845/ You have a panel, so why not use the 40amp wiring behind the cigarette lighter type plug? You could hard wire it in and not have to use the alligator clips.
