2.4 Liter Gas
Originally Posted by 1BadPig
I've used regular for the first 3000 miles and now using 93 the last couple of fill-ups to compare now that gas prices have come down. I cannot tell that much of a difference, except slightly quicker acceleration. The mileage is about the same. I will switch back to regular as there is no obvious or overwhelming benefit to premium.
Originally Posted by teknobunie
that is scary!
You would not worry about the damage it may be causing???????
We really don't know the long term effect yet.
I think the effects of what detonation and pre-combustion will do have been known sice the time the first internal combustion motor was developed.
Boy Oh Boy! All I was saying is that we have no clue what it will do with our new "ECOTECH" engine, by the way are you a engineer or a mechanic? Just wondering.
"The HHR is not a high combustion boosted motor, it's an economical 4 cylinder."
Actually, the 2.4L Ecotoec in the HHR has a compression ratio of 10.5:1 - which is a rather high combustion engine by today's standards. This is the reason for the higher octane rating.
As far as damage, GM has put a pretty good engine management system in place, and with variable valve timing, anti-knock sensors, etc. You shouldn't sustain any damage unless you experience audible knocking.
I've run both grades in my 2.4L, and have seen noticeable improvements in both power and mileage using premium. Now that gas prices have subsided a bit, I will continue to run the good stuff. (*As a side note; a bottle of octane booster will set you back $5 or so - that's MORE than filling up with premium in most cases.)
Hope it helps,
Hope it helps,
Hope it helps,
Hope it helps,
I'm glad I quit!
