2006 HHR LT 2.2L - Manual - Cat Converter ?
Old Jul 20, 2022 | 03:19 PM
CC819's Avatar
Originally Posted by donbrew
$87 wasn't a ":wow"?
im a little afraid of it because it’s too cheap 😳….
Old Jul 20, 2022 | 03:58 PM
I liked that it’s mandrel bent and 2” ID , not 1 3/4 , so it’ll let that 2.2 breath a bit better
Old Jul 20, 2022 | 04:02 PM
If you aren't going to look for and fix the cause of failure it wouldn't be very smart to spend a lot of money on a part that will surely fail.
What brand O2 sensor was installed?
One thing that could be done is to have an old fashioned emissions gas test done to see if there is really a problem (the kind with a probe up the tail pipe).
Old Jul 20, 2022 | 04:53 PM
CC819's Avatar
I believe they were Bosch from Autozone…I guess when I pull the old one off I’ll see if there’s any damage. I’ve had the F/I cleaned all new plugs, new ignition box done already…coolant is new and the oil…code just randomly popped up..I’m going to change out the upper 02 sensor when I do the Cat.
Old Jul 20, 2022 | 04:59 PM
If they're Bosch, try replacing them first, they have caused problems before.
Old Jul 20, 2022 | 05:02 PM
  #26
PulpFriction's Avatar
Is it the original cat? If so, you would be throwing away a very expensive part, so be really really sure it’s necessary first. Sometime fixing other issues and/or taking a nice long drive can improve things by burning off some gunk in the cat.
How long was the P0420 set? (Time and miles. Wild guess is fine.) Do you take a lot of short trips?
Any other codes, now or before the the P0420? Any other issue before or concurrent to this one?
Which O2 sensor? (I don’t even know if there are two on this car.) And what maker and part number?
(Assuming not P04020 but P0420 Catalyst System Low Efficiency.)
Old Jul 20, 2022 | 07:34 PM
  #27
There is a recall involving the programming TSB # 05-06-04-073 for the 2.2L giving false P0420. If the VIN is lower than 6S559494 it needs updated ECM firmware.
I was afraid you would say Bosch, they are a problem.
Here is a pdf of the TSB:
TSB05-0604-073.pdf
Old Jul 20, 2022 | 08:19 PM
  #28
Yes , Bosch are a known problem, I installed GM
Up and down stream
Old Jul 20, 2022 | 10:01 PM
  #29
greg8453's Avatar
That's not enough platinum to covert a single cylinder engine.
Old Jul 20, 2022 | 11:06 PM
  #30
Is that tiny flex section going to do the job?
