2006 LT - Turn Signal not cancelling both directions
Old Jan 24, 2020 | 11:22 AM
RainmanQQ's Avatar
Hi: I've read most of the posts here on the forum, and here is our current status. The previous owner has replaced the turn signal switch with an aftermarket one, it was black instead of grey, and the signals worked for the first couple of weeks after we purchased it. Then the signal would not cancel on both left and right turns, so after reading on here and watching a couple of videos, I ordered a genuine GM turn signal switch in grey for $28.96 shipped to me, and installed it pretty quickly, but no luck on the cancelling. I made sure the switch snapped in tightly. I even put the old switch back in, but no luck, so I went down to our mechanic to show him, and he pulled the signal switch back out, and looked it, and showed me a round piece of black plastic that was kind of just floating/spinning around inside. Assuming that is what is supposed to control the cancelling on the little white tab on the signal switch. Anyway, he and the dealer he called said to order an airbag/clock switch and that should take care of it. Has anyone ever replaced one of these before? Assuming the wheel has to come off, and hopefully pretty straight forward from there. I ordered an new AC Delco clock spring for $115.61 delivered to my door. I checked with our dealer, and he confirmed this number as the correct part number. Any hints or suggestions?
https://www.oempartsource.com/oem-pa...pring-20940100
Old Jan 24, 2020 | 12:42 PM
Cat Man HHR's Avatar
Sorry had to break this into lines to understand it more.
Old Jan 24, 2020 | 02:44 PM
Well you saved some money
https://www.rockauto.com/en/partsear...rtnum=20940100
and got an OEM part.
Several threads about the clock spring
https://www.google.ca/search?q=how+t...&bih=626&dpr=2
Lucky shared this procedure
Steering Wheel Inflatable Restraint Module Coil Replacement Removal Procedure
Notice: The new SIR coil assembly will be centered. Improper alignment of the SIR coil assembly may damage the unit, causing an inflatable restraint malfunction.
1.Place the front wheels in the straight forward position with the steering wheel centered.
2. Disable the SIR system. Refer to SIR Disabling and Enabling .
3. Remove the inflatable restraint steering wheel module. Refer to Inflatable Restraint Steering Wheel Module Replacement .
4. Remove the steering wheel. Refer to Steering Wheel Replacement .
5. Remove the steering column covers. Refer to Steering Column Trim Covers Replacement .
6. Disconnect the SIR coil harness connector from the SIR coil module assembly.
7. Disconnect the headlamp/turn signal harness connector from the SIR coil module assembly.
8. Disconnect the wiper/washer harness connector for the SIR coil module assembly.
9. Using a small flat-bladed tool, carefully pry the 2 retaining tabs away at the base of the SIR coil assembly and slide the SIR coil assembly off of the steering column.
10. Remove the headlamp/turn signal switch from the SIR coil module assembly. Refer to Turn Signal Multifunction Switch Replacement .
11. Remove the wiper washer switch from the SIR coil module assembly. Refer to Windshield Wiper and Washer Switch Replacement .
Installation Procedure
1. Install the wiper washer switch from the SIR coil module assembly. Refer to Windshield Wiper and Washer Switch Replacement .
2. Install the headlamp/turn signal switch to the SIR coil module assembly. Refer to Turn Signal Multifunction Switch Replacement .
3. Install the headlamp/turn signal switch screws.
4. Verify the SIR coil is in the center position. Refer to Inflatable Restraint Steering Wheel Module Coil Centering .
5. Slide the SIR coil assembly on the steering column and snap into place.
6. Connect the wiper/washer harness connector to the SIR coil module assembly.
7. Connect the headlamp/turn signal harness connector to the SIR coil module assembly.
8. Connect the SIR coil harness connector to the SIR coil module assembly.
9. Install the steering column covers. Refer to Steering Column Trim Covers Replacement .
10. Install the steering wheel. Refer to Steering Wheel Replacement .
11. Install the inflatable restraint steering wheel module. Refer to Inflatable Restraint Steering Wheel Module Replacement .
12. Enable the SIR system. Refer to SIR Disabling and Enabling .
____
Old Jan 24, 2020 | 03:25 PM
Pull the airbag fuse and wait 20 minutes before you start.
Old Jan 24, 2020 | 03:26 PM
That's nice info, but the person is chasing his shadow right now.
Old Jan 24, 2020 | 03:37 PM
The clock spring is broken, that’s the information I found about how to replace it. How is that about chasing one’s shadow?
Old Jan 24, 2020 | 03:50 PM
He changed the lever and now is going to change the clock spring.
Never found the cause of the problem.
Old Jan 24, 2020 | 06:44 PM
RainmanQQ's Avatar
Assuming something on the clock spring has broken, based what my mechanic said after taking a look at it, and seeing something that looks like it has come apart. Not sure what would have caused it, maybe age, as these items in question have some plastic pieces that can snap due to age and usage. Will keep everyone posted on the results.
Old Jan 24, 2020 | 09:06 PM
Last person with this issue said it was a plastic bit on the column that broke off. Maybe it is attached to the clockspring, IDK.
Old Jan 25, 2020 | 03:04 PM
RainmanQQ's Avatar
Will definitely let everyone know the final result.........
