2008 engine
2008 engine
Was just looking through the 2008 HHR brochure and noticed this pic. Don't think anyone has pointed it out yet.
I believe this is a 2.4 since the caption says "HHR 2LT in Sunburst Orange II Metallic."
Notice the new engine shrouds!
Looks much nicer and looks like a re-work intake system.
Anyone of you who's driving 08's, TOM!!, how about a pic or two of the engine please?
He posted some here: https://www.chevyhhr.net/forums/show...?t=9334&page=3 no visible changes...
That is the shroud and intake tract for 2.2 Ecotecs. Impalas, Malibus, and Cobalts all have the same set-up, might just be a printing mistake...
Edit...
I stand corrected, they changed the 2.4, in my defense they have that same design shroud on 2.2s (so i wasn't TOTALLY wrong)
http://www.gminsidenews.com/naias/engines/eco2400.jpg
Edit...
Anything would be better than the one used now!
The 1LT was a 2.2 and the 2LT was a 2.4 both with the big air intake, could the brochure be the sneaky of the 2.0 engine? might just have to go searching........hmmmmmmmmmm
This engine layout is a PITA to do the oil change on. This setup is on the wife's 2.4L G6, the plastic cowling gets in the way of the oil filter cap so you can't fit the same kind of tools you can use on the HHR on it (my socket doesn't have enough clearance). When I did the oil change on her car, I had to use a set of vice-grip pliers, which in turn kind of chewed up the hex on the cap.
There is already a pic of the 2.0 which has been posted in the SS threads.
