2LT vs 1LT
Old Oct 13, 2006 | 05:59 PM
Snoopy's Avatar
Originally Posted by Dave C
Look in the glove box on the inside of the "door" there will be a placard that says "SERVICE PARTS IDENTIFICATION". It contains info on how the vehicle was built. You will be looking for FE3 That is the code for the Sport Suspension System that is ONLY available on the 2LT.
If you see FE1 then it has standard suspension and is NOT a 2LT.
Good Luck
Now, here is a bright guy.!!!!!!
Old Oct 13, 2006 | 10:34 PM
FlintHHR's Avatar
Perfct, that is what I was looking for. I have called a couple dealerships and they didn't have the option list for it, so next time I will tell them to look in the glove box and tell me what the sticker says.
Old Oct 13, 2006 | 11:15 PM
courthousedeb's Avatar
Nice piece of info Dave C. Thanks for the heads up.
Old Oct 14, 2006 | 12:26 PM
JoeR's Avatar
The easiest way to spot a 2LT is the fact that it is the ONLY model that comes from the factory with 17" wheels and tires!
Somebody mentioned anti-roll bars... All the models come with a 25 mm front bar and a 22 mm rear bar, BTW. The 2LT comes with the gas shocks.
Old Oct 14, 2006 | 04:00 PM
Cobra65's Avatar
Is it just me or does the 2LT's rear springs look thicker than the LS/1LT's also?
Old Oct 14, 2006 | 04:17 PM
Snoopy's Avatar
Don't know if it matters and GM parts books are not ALWAYS correct but, there is only one listing for rear springs. Which could mean all models share the same rear springs. Two different listings for shocks, however. "Soft" suspension and "Sport" suspension.
Old Oct 14, 2006 | 05:45 PM
FlintHHR's Avatar
The problem with the 17" tires is that someone could buy a 1LT and swap the 16" with 17" wheels/tires. That is why I was wondering about a sure way to tell, such as the glove-box sticker as was stated earlier. Still waiting for someone to load pics of shocks from regular HHR.
Old Oct 15, 2006 | 01:25 AM
SoCalHHR's Avatar
The 1LT shocks will not have that "warning" sticker on them. The sticker warns of potential explosive hazards when disposing of the pressurized shocks in a fire. The 1LT's standard shocks will not have such a sticker.
Hope it helps,
Old Oct 15, 2006 | 01:14 PM
FlintHHR's Avatar
Hope it helps,
Gotcha, thnx for the help guys, knew I could count on all of you. Now I know what to look for.
Old Oct 15, 2006 | 05:46 PM
JoeR's Avatar
Here's how to be SURE...
Look on the window sticker... on the right side under "Options & Pricing"....
The first option listed on my sticker is:
2LT PREFERRED EQUIPMENT GROUP
