AC Issues
Old Jul 11, 2024 | 11:05 PM
No Windows's Avatar
Im a novice with multimeters. Can you explain how I should test it with one please oh please??? Thanks Don
Old Jul 12, 2024 | 08:28 AM
Set to OHMS. Place red lead on one side black lead on other, look at meter; then reverse leads. OL means blocked, any number means continuity (0.00 is a number). Diode is bad if you read continuity in both directions.
Pretty rare the diode is the problem. More likely the engine coolant t-stat is stuck open, if your problem is no AC and digital temp displays ---. Replace it with ACDelco 131-158 ONLY.
Old Jul 12, 2024 | 08:32 PM
No Windows's Avatar
Thanks Donbrew -
I was hoping the diode was bad but it tested fine. Crossing one thing off the list at least. Still cant get the clutch to kick in. I appreciate the help sir.
Old Jul 12, 2024 | 08:51 PM
What about the t-stat?
LON
Jul 29, 2023 08:06 AM
Badco78
Jul 2, 2021 05:37 PM
drscott
Jul 1, 2019 11:24 AM
SwaintaN
Aug 21, 2018 01:35 PM
jerij
May 30, 2006 10:58 AM
